timbeadle@ozemail.com.au Guest
Posted: Sun Apr 03, 2005 4:12 am Post subject: changing AMD K-5 machine to K6-2 350 or 450 cpus |
| Are there any dramas in changing from a K5 to K6-2 cpus . The motherboard ia Gigabyte GA586 ATV or ATX. I believe both boards have auto select for cpu voltages. Any help would be appreciated. Regards Tim Beadle |
Posted: Sun Apr 03, 2005 12:56 pm Post subject: Re: changing AMD K-5 machine to K6-2 350 or 450 cpus |
K6-2 CPUs have 2.2V core voltage. It seems the GA586 ATV does not support this voltage, so the fastest AMD CPU you can upgrade to on this board is K6-233.
I couldn't find manual for GA586 ATX board, maybe it can support K6-2 processors?
