HYUNDAI/KAIST HK386 SAMPLE
goodeegg
PostPosted: Sun Jun 27, 2010 7:12 am    Post subject: HYUNDAI/KAIST HK386 SAMPLE Reply with quote
HK386(1995.9) : an x86-compatible 32bit ClSC microprocessor
Chip Feature
- 32-bit microprocessor which is pin and instruction level compatible with Intel’s i386.
- 0.8 mm CMOS technology
- Package: 132-pin PGA
- Die size: 1.0  1.0 cm2
Architectural Feature
- Pipelined Instruction Execution
- 64 Terabytes Virtual Address Space
- Integrated Memory Management
- Unit (MMU)
- On-Chip Address Translation Caches
HYUNDAI(Hynix) : http://www.hynix.com
KAIST : http://vswww.kaist.ac.kr
PDF FILE
PostPosted: Sun Jun 27, 2010 7:25 am    Post subject: Reply with quote
very impressive stuf!!!
PostPosted: Sun Jun 27, 2010 11:58 am    Post subject: Reply with quote
THAT is cool!
pinkie
PostPosted: Tue Jul 06, 2010 9:56 am    Post subject: Reply with quote
Cooooool!
Do you have more info about the core? made by intel or HYUNDAI ?
Yan
goodeegg
PostPosted: Fri Jul 09, 2010 4:21 pm    Post subject: Reply with quote
pinkie wrote:
Cooooool!
HYUNDAI and KAIST Reader Development
http://ics.kaist.ac.kr/ver3.0/intcpapers/HK386%20-%20An%20x86-compatible%2032bit%20CISC%20Microprocessor.pdf
