Kidfork Guest
Posted: Thu Jul 01, 2010 10:25 pm Post subject: Will it work? |
Alright so I just ordered a
Intel Pentium Dual-Core E5400 Processor BX80571E5400 - 2.70GHz, 2MB Cache, 800MHz FSB, Wolfdale, Dual Core, Retail, Socket 775
for this motherboard
ECS 945GCT-M3(V3.1)
However its not on the support list. BUT core 2 duo processor's are supported. Also my current processor is a Pentium E2140
THe new one is a 45nm while the old is a 65mn. I imagine this Pentium would work if a higher model would. |
Tetrium
Posted: Fri Jul 02, 2010 4:41 am Post subject: Re: Will it work? |
| Kidfork wrote: | Alright so I just ordered a
ECS 945GCT-M3(V3.1)
It's a good educated guess it would work.
Have you tried googling your motherboard and cpu? Often someone somewhere on this planet had the same question and posted about it on some forum  |
Cobracon
Posted: Fri Jul 02, 2010 10:23 pm Post subject: |
If the e5400 isn't on the CPU support list for your motherboard, I seriously doubt it will work. _________________ "Have you scanned the RAM timings for Operator's Headspace?? Too much real estate between the audio collectors will block the connection which allows proper operation of your computer."_Cobra
