forever577
Posted: Fri Jul 02, 2010 12:16 am Post subject: amd athlon xp "Barton 2500 |
| I have a amd athlon XP Barton 2500 its running at 59-60 C what is the normal temp of CPU and is it ok to run at that temp.am running a cooler master fan running between 4450-4600rpm and heat sink it came with the cooler master |
Posted: Fri Jul 02, 2010 2:59 am Post subject: |
Have you appkied a layer of thermal paste between the cpu and the heatsink?
How old is the setup (e.g. you mounted it 6 years ago, 1 month...)?
It's not surprisingly high temps, but is that at full load or idle? |
Tetrium
Posted: Fri Jul 02, 2010 4:40 am Post subject: |
Try installing speedfan and after that play a game for about 15 minutes.
After you've gotten back on your desktop you can view a graph of what the cpu temps were.
Did it reach 80c? Then it's getting too hot!
If it's getting too hot it can mean one of 3 things:
-The HSF isn't installed/working properly
-Case ventilation isn't good enough
-The HSF isn't adequate to cool a cpu with this heat production |
forever577
Posted: Sun Jul 04, 2010 1:11 am Post subject: amd athlon cpu overheating reply |
| HSF running at 4440-4600 rpm everest and bios confirms thatBy the way this is a Gigabyte KT600P-RZ motherboard its 5.5 years old and the cpu is about 9 yrs old all installed in a P3 case .New paste on the cpu Cooler master HSF |
Posted: Sun Jul 04, 2010 3:37 am Post subject: |
It's a little high, have you installed the heatsink in the right way?
Once I reversed the position and I got those 10° more.
Can you describe the heatsink, maybe as suggested it is too fair for that cpu, or it was bundled with it in the box with it? |
