thebandit2005
Posted: Mon Apr 18, 2005 5:38 pm Post subject: help please (confused) |
hi i am confused on what chip too buy ..could anyone help me?
an amd athlon64 3000 socket 757 or an athlon64 3000 939 socket??
what is the difference etc cuz i have no clue |
chipcollector
Joined: 28 Sep 2004 Posts: 1681 Location: New England
Posted: Mon Apr 18, 2005 5:41 pm Post subject: |
It all depends if you have a motherboard, whether it supports socket 939 or 757. If you haven't purchased a motherboard yet, I'd go with the 939, more pins means more bandwidth. So you get better performance  |
thebandit2005
Posted: Mon Apr 18, 2005 5:45 pm Post subject: |
i was wanting too buy the asus a8v deluxe wifi-g f (socet 939) .
this i all i was gonna buy what do you think??
amd athlon64 3000 socket 939,
asus motherboard
160gb hard drie with 8 cache
68bit graphics card
512 ddr 400 memory.
would this be a very fast and good pc?? |
chipcollector
Posted: Mon Apr 18, 2005 5:53 pm Post subject: |
| everything looks good except the 3000 processor. Can you tell me how much you're paying for the processor? I can try to find you a better one for a lot cheaper |
thebandit2005
Posted: Mon Apr 18, 2005 5:55 pm Post subject: |
i'm paying £110 for it..is it not a good cpu then the athlon64 3000 socket 939??
which one would you recommend |
chipcollector
Posted: Mon Apr 18, 2005 6:16 pm Post subject: |
Right now on pricewatch.com you can get that 939 cpu for 71 British Pounds. But for now let's forget that this price ever existed because you'll want to upgrade for the same amount of money you were going to pay before
Now over here http://www.monarchcomputer.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=M&Product_Code=120422
you can buy an Athlon 3200 64bit 939pins for $180, and instead of paying $215(114 British pounds) for a Athlon 3000 you can upgrade and save money!!! By doing this, you get a faster and better processor but spending $35 less ( 18.5 British Pounds less ).
Yes I outdid myself, thank you, thank you
CPU-Shack has an excellent service to buy things from websites that ship only to the United States and then reship them to other countries. Hope this helps !
Paul
Edit: I Put the wrong link, fixed it now. Sorry! |
thebandit2005
Posted: Mon Apr 18, 2005 6:18 pm Post subject: |
| so the amd64 3200+ is the better processor...what mhz does it run at?? 2.0?? i can get it here for £137 retail with fan etc which is not to bad |
chipcollector
Posted: Mon Apr 18, 2005 6:25 pm Post subject: |
WOW 137 British Pounds! That's 259 US Dollars, you can buy the 64 3500+ for that same amount of money.
Ok if you want to buy a 3200+ 64, which would have cost you 137 Pounds will now cost only 95 British Pounds. Do you have MSN or anything like that? I can help you out through there a lot faster
Thanks
yes the 3200+ runs at 2.0 ghz, and the 3500+ runs at 2.2ghz |
thebandit2005
Posted: Mon Apr 18, 2005 6:28 pm Post subject: |
| i have msn and aol messanger..which one would you want |
chipcollector
Posted: Mon Apr 18, 2005 6:34 pm Post subject: |
aol  |
