K7VM3 Motherboard CPU question...
Ron Mexico
PostPosted: Tue Oct 19, 2010 10:25 am    Post subject: K7VM3 Motherboard CPU question... Reply with quote
Hello,
Even though the specs say the CPU can run at a max of 333 MHz FSB, can I use a Athlon 3200 that runs at 400 MHz? If so, can I use the Hybrid Booster to obtain the full benefit of the Athlon 3200?
PostPosted: Tue Oct 19, 2010 12:01 pm    Post subject: Re: K7VM3 Motherboard CPU question... Reply with quote
You can, but the CPU will run at 2.2 GHz * (333/400) = 1.83 GHz.
I never used this utility, but if it allows you to overclock FSB then, because your processor will not be actually overclocked, it may work.
Thank you!
viili
PostPosted: Tue Oct 19, 2010 1:45 pm    Post subject: Reply with quote
You'd be overclocking your chipset if you set bus speed to 400MHz. It may cause instability. Only way to be sure is to try it.
Ron Mexico
PostPosted: Tue Oct 19, 2010 2:29 pm    Post subject: Reply with quote
I'm new to overclocking... what are the risks?
PostPosted: Tue Oct 19, 2010 2:55 pm    Post subject: Reply with quote
And sorry, one more question...
If I were able to use the Hybrid booster to increase the frequency (FSB) to 400 MHz, does that mean I would be able to use ram that is designed to run at higher frequencies?
For example, the MB is designed to take DDR333 (up to 2 GBs). Could I then use DDR-400 RAM?
Thanks again, and sorry for all of the questions!
viili
PostPosted: Wed Oct 20, 2010 12:20 am    Post subject: Reply with quote
Data corruption is possible.
PostPosted: Wed Oct 20, 2010 2:35 am    Post subject: Reply with quote
You can use DDR 400 Mhz without any problem.
Ron Mexico
PostPosted: Wed Oct 20, 2010 6:07 pm    Post subject: Reply with quote
And both the RAM and overclocked CPU will be able to run at this FSB frequency (provided adequate cooling) despite the motherboard being rated for only 333 Hhz?
PostPosted: Thu Oct 21, 2010 2:12 am    Post subject: Reply with quote
VIA KM266Pro were not super overclockable chipset so in my opinion there are only small chances. But well worth to try. Overclocking effect depends on : chipset, CPU, RAM, power supply.
