amd2000 Guest
Posted: Sun Apr 24, 2005 1:34 pm Post subject: about the amd athlon64 |
hi i just went and bought and amd athlon64 3200 on the socket 939 and it comes up on windows as a 1.80gb is that correct?? i find my pc is sluggish but i have got a sata hard drive at 80gb and it seems not too good. wil the windows xp pro 64bit make my processor work at a better rate than it is or is it just microsoft conning ppl again?? i am happy with my amd cpu tho it really was fun building it but my memory is ddr2 400mhz 515 so maybe i should upgrade it and it may do better. what do you al think??
also what can you say about the asus a8v deluxe wifi motherboard as it is what i bought?? |
chipcollector
Joined: 28 Sep 2004 Posts: 1681 Location: New England
Posted: Sun Apr 24, 2005 1:40 pm Post subject: |
Ahh so you thought it was 3.2ghz?!!  |
amd2000 Guest
Posted: Sun Apr 24, 2005 1:41 pm Post subject: |
| nah i thought it was a 2.0ghz cpu but i guess not |
chipcollector
Posted: Sun Apr 24, 2005 1:49 pm Post subject: |
| It IS 2.0ghz, or at least in your case it's supposed to be |
amd2000 Guest
Posted: Sun Apr 24, 2005 1:51 pm Post subject: |
| well it is comming up as 1.80ghz on windows description when i right click my computer and goto properties...is there a tool i can download too check it?? |
skold
Posted: Sun Apr 24, 2005 6:41 pm Post subject: |
check the bios settings first.. i havent had any first hand experience with athlon 64s, but usuall showing the wrong clock speed is a result of having the wrong fsb or multiplier set
also, you can try disabling the cool'n'quiet setting, if its in your bios. afaik that makes the chip clock itself down when its not being used, so it may be throttling back to 1.8ghz since it doesnt need to run at 2ghz. |
amd2000 Guest
Posted: Mon Apr 25, 2005 9:19 am Post subject: |
| i have a disk to upgrade to windows xp pro 64bit..should i use it or what do you think i should do?? |
Posted: Tue Apr 26, 2005 8:13 am Post subject: |
| Hi amd2000, go to: http://www.lavalys.com/ ,download and install EVEREST Home Edition v1.51 (freeware 3 Mb), run it, click Computer > Overclock, there You can see CPU Speed > CPU Clock (with realtime CPU speed). |
