nubie92503 Guest
Posted: Sun Jan 02, 2011 1:25 pm Post subject: help with issue |
hi everyone
need your help a have a gateway e2610s desktop and i been having issues since a got it from a friend
Here is the problem some time the computer shutdown by itself and my monitor display going to sleep
other time the monitor screen turn on to colored horizontal and vertical lines.
So i was Wonder if it is a cpu problem or maybe a gpu problem
THANKS FOR YOUR HELP |
Tetrium
Posted: Sun Jan 02, 2011 1:35 pm Post subject: |
| Sounds more like a GPU problem |
Posted: Sun Jan 02, 2011 3:13 pm Post subject: |
Check if the gpu fan is working if there's one. Otherwise try to blow fresh air on the gpu card and see if it stops.
If it's an integrated video card, maybe the chipset is overheating.
It might be a driver issue, maybe try uninstalling the drivers and reinstall them after a reboot.
d. |
nubie92503 Guest
Posted: Sun Jan 02, 2011 4:52 pm Post subject: |
| everything is working fine this motherboard do no have a gpu fan |
