JKrcmik Guest
Posted: Tue Jan 04, 2011 12:51 pm Post subject: AMD Athlon 64 X2 7750 Black Edition on GA-M68SM-S2 |
| Is AMD Athlon 64 X2 7750 Black Edition compatible with Gigabyte GA-M68SM-S2? I just checked GIGABYTE site and there was this sign "-" which means it have never been tested, I guess. But on GA-M68SM-S2L it is. GA-M68SM-S2 and GA-M68SM-S2L aren't so different i think. Thanx for answer. /jkrcmik@gmail.com/ |
Posted: Tue Jan 04, 2011 3:39 pm Post subject: |
It shows that the board doesn't support any Phenom X3 and X4 processors. Since Athlon X2 CPUs have the same core design and stepping as the Phenoms, I suspect they are not supported either.
JKrcmik Guest
Posted: Tue Jan 04, 2011 4:19 pm Post subject: |
| Thank you |
