x64 processors?
Glory_Cloud
PostPosted: Thu Feb 10, 2011 5:24 pm    Post subject: x64 processors? Reply with quote
Duh question. Cool
I need to get a server with at least an x64 processor
in it and I wouldn't know one if it bit me on the leg.
I need a server that I can use to image drives for
the non-profit that I have. I can get low cost server
software from Microsoft like Small Business Server 2008
up to the 2011 version. I have access to low cost servers as well
but I need a little guidance from this august group as to what
type processor I can minimally get by with. Smile
PostPosted: Thu Feb 10, 2011 6:05 pm    Post subject: Reply with quote
your cheapest option for a 64 bit server would be something using Nocona or Irwindale xeons.. way cheaper than finding an AMD alternative
I will do a search and see what i can find.. in Florida area??
Glory_Cloud
PostPosted: Thu Feb 10, 2011 6:18 pm    Post subject: Reply with quote
Are they 3.0Mhz and above? I have some dual Xeon 3.0's
like the SL7PE's
PostPosted: Thu Feb 10, 2011 6:30 pm    Post subject: Reply with quote
like the SL7PE's
long as they are 800FSB.. they will be 64 bit.. and SL7PEs are Smile
PostPosted: Thu Feb 10, 2011 6:42 pm    Post subject: Reply with quote
AMD 24x/84x Opterons can be had for less than $10 a piece, and they all support 64-bit.
PostPosted: Thu Feb 10, 2011 6:51 pm    Post subject: Reply with quote
the only thing i find it is hard to source cheap board & heatsinks for Opterons
Glory_Cloud
PostPosted: Fri Feb 11, 2011 5:35 pm    Post subject: Reply with quote
Thanks! I may just go with a simple dual Xeon 3.0Ghz IBM 1U server.
I think that may be enough to run SB server 2008 if I get 4G and
a couple of 146G SCSI drives.
