Motherboard incompatible with CPU?
haydz
PostPosted: Sun May 08, 2005 1:20 am    Post subject: Motherboard incompatible with CPU? Reply with quote
GIGABYTE GA-7VT600P-RZ Socket A Motherboard is the motherboard I have recently aquired. I have an AMD athlon 2800 xp or it might be 3200 :S I threw out the box and no hardware can identify it.
My CPU is running at 1110.95 MHz and FSB 101.00 MHz, they should be running at a much higher speed than this! I have two 512 Kingmax ram in there, but it is only showing up as 512.
Are my two components incompatible Sad? if they arent then what could be the problem? I have already reset the bios, and tried gigabytes bios settings and no luck!
Can anyone help me Smile? anything ive missed?
Haydz
haydz
PostPosted: Sun May 08, 2005 1:29 am    Post subject: Reply with quote
well i found out that they are compatible, so it must be the memory?
yes/no?
Vlad The Impaler
PostPosted: Sun May 08, 2005 1:36 pm    Post subject: Reply with quote
You need to change a jumper on the mobo to increase the FSB to 166mhz
Vlad The Impaler
PostPosted: Sun May 08, 2005 1:37 pm    Post subject: Reply with quote
Or 200 if it is an XP3200. You may want to find that little point out before you go any further.
PostPosted: Wed May 11, 2005 3:10 pm    Post subject: Reply with quote
Hello,
Try update bios. -RZ is good mobo for Athlon 3200+ Wink Your components are very good. If does not help send reply and I will find help fot this problem ...
PostPosted: Thu May 12, 2005 5:04 pm    Post subject: Reply with quote
Marcin Majewski wrote:
Hello,
Try update bios. -RZ is good mobo for Athlon 3200+ Wink Your components are very good. If does not help send reply and I will find help for this problem ...
