Laci Guest
Posted: Sat Feb 19, 2011 5:06 pm Post subject: Laptop CPU upgrade |
Hy!
I have an asus k42jv-vx051d laptop. The laptop has a core i5-450m cpu.
I intend to buy a core i7-720 or 740cpu. Is it possible to exchange?
Thank you for your answer.
Laci |
Posted: Sun Feb 20, 2011 1:45 am Post subject: |
| Depends on the laptop BIOS. Seems that 450m and 720 are both PGA988 socket. Well, the i7 can produce 10W more heat so that could also be a problem, but wont stop the processor from starting up, just could make it overheat when stressed. |
Laci Guest
Posted: Sun Feb 20, 2011 5:38 am Post subject: |
| Yes, i understand. So i should refresh the BIOS too. It is risky isn't it? |
Posted: Sun Feb 20, 2011 1:32 pm Post subject: |
| Yes, especially on a laptop. You should ask the manufacturer if the BIOS supports i7 processors, maybe you don't need an update. |
Laci Guest
Posted: Mon Feb 21, 2011 6:16 am Post subject: |
I have an another question too.
i saw that there are two type of i7-720qm processor.
the one is SLBY and the another is Q3BA
what are the differences between the processors? |
Posted: Tue Feb 22, 2011 1:14 am Post subject: |
SL* processors are production parts, and they are usually covered by OEM or Intel warranty. Q* parts are qualification or engineering samples. They may have fully or partially unlocked clock multiplier, but on the downside they are not warranted by Intel. Engineering samples may also contain defects, not found in production chips.
