Silver bottom pentium overdrive!
susl45
PostPosted: Sat Feb 26, 2011 12:04 am    Post subject: Silver bottom pentium overdrive! Reply with quote
The Silver bottom pentium overdrive appear again,LOL
Here is one pentium overdrive I just got, silver bottom.
I remember Leevmeister showes one some time bofore, his is PODP 200 SL2FF V2.8 version.
It is a pity, the original HS was missing..
But look at the caps on front side, I can not remember which kind of PODP has this type caps...
http://img.ph.126.net/zQe5ILVOrhXELO2f8NF5PA==/2304435634330770934.jpg
http://img609.ph.126.net/eEQnojI9zhUxvap2qK81rw==/1655072863060806517.jpg
PS: I failed to upload the pic directly using [img][/img], I use like this:
[img]http://img609.ph.126.net/eEQnojI9zhUxvap2qK81rw==/1655072863060806517.jpg[/img]
But it does not work, is my operation wrong?
Trade list
http://www.cpu-world.com/forum/viewtopic.php?t=15832
PostPosted: Sat Feb 26, 2011 12:11 am    Post subject: Reply with quote
must be due to special characters in file name.. wont work for me either
PostPosted: Sat Feb 26, 2011 12:14 am    Post subject: Reply with quote
only these were manufactured in week 23 1997
SL24W PODPMT66X166 V1.1
SL2FE PODPMT60X180 V2.0
susl45
PostPosted: Sat Feb 26, 2011 12:16 am    Post subject: Reply with quote
Thanks for info. but I cannot identify what kind of special characters there... Crying or Very sad
Trade list
PostPosted: Sat Feb 26, 2011 12:24 am    Post subject: Re: Sivler bottom pentium overdrive! Reply with quote
These were on all SL24V & SL24W V1.0
but also on early SL24W V1.1 & SL2FE
PostPosted: Sat Feb 26, 2011 2:25 am    Post subject: Reply with quote
Only those ? I have PODPMT66X200 SL2FF V2.8 with same silver cap :
http://www.abc-cpu.com/component/option,com_ponygallery/Itemid,62/func,detail/id,1442/#ponyimg
http://www.abc-cpu.com/component/option,com_ponygallery/Itemid,62/func,detail/id,1443/#ponyimg
PostPosted: Sat Feb 26, 2011 2:28 am    Post subject: Reply with quote
The silver caps are remarked 166 or 180s
The silver cap hides where they have played with the multiplier pins to increase the speed to 200
susl45
PostPosted: Sat Feb 26, 2011 6:32 am    Post subject: Reply with quote
Yours is the same as Leevmeister's one.
Trade list
susl45
PostPosted: Sat Feb 26, 2011 6:36 am    Post subject: Reply with quote
Here is the pic of removed silver cap.
http://img116.ph.126.net/spiLJkTSLoexVsxgi8O70w==/709035466335928573.jpg
The cpu core are filled with black glues and stick to silver cap.
Why the faker remove the original bottom and make the silver one... , I do not think they want to refine the gold.
In fact, they do not need to do it, they only need do some works on front side, then it would be enough.
Trade list
PostPosted: Sat Feb 26, 2011 12:35 pm    Post subject: Re: Silver bottom pentium overdrive! Reply with quote
The have to remove the plate to alter the multiplier
susl45
PostPosted: Sat Feb 26, 2011 12:41 pm    Post subject: Re: Silver bottom pentium overdrive! Reply with quote
How to alter the multiplier, is it easy?
Trade list
PostPosted: Sat Feb 26, 2011 12:57 pm    Post subject: Re: Silver bottom pentium overdrive! Reply with quote
yah just change how a couple pins are connected.
PostPosted: Sat Feb 26, 2011 8:23 pm    Post subject: Reply with quote
Susl45, Your pic doesn't appear when I click on your link... Confused
Is it because of a government "curtain" blocking it?
My collection list (growing) http://johnorun.x86-guide.com/en/collection.html
smithy
PostPosted: Sat Feb 26, 2011 8:36 pm    Post subject: Reply with quote
Reload the page after you've clicked on the link and it will come up
PostPosted: Sat Feb 26, 2011 8:42 pm    Post subject: Reply with quote
Chrome does not properly work with such URLs, Firefox will though
Here it is:
