dualcorebeast Guest
Posted: Tue Mar 01, 2011 9:20 am Post subject: Best Cpu For Board or is it cheap to buy new everything |
hey i have a P35_Neo2-FR
www(.)cpu-upgrade(.)com(/)mb-MSI/P35_Neo2-FR___FIR(.)html (remove )()()()
with 4gb ram 800mhz
currenlty running a e8400
i want to know what cpu (no extremes) is the best cpu, or is it better to upgrade the ram, or both with the new cpu?
thanks guys |
Posted: Tue Mar 01, 2011 9:30 am Post subject: |
What applications you are using where you are getting to slow result ? E8400 is 3,00 GHz CPU which is one of the fastest from dual cores. 4GB of DDR2 is enough for most applications today.
If you expect extra boost than change platform to quad or six core cpus on newer sockets like 1366, 1155, AM3.
Performance not only depends on CPU and RAM - everything must works on good chipset too. _________________ Visit ABC CPU - Virtual CPU Museum. |
dualcorebeast Guest
Posted: Tue Mar 01, 2011 9:36 am Post subject: hope this helps |
i am running bots, and my cpu is 100% all the time and i am using 2.93ghz
its a java bot if that helps and it runs in 64 bit java if that help futher |
dualcorebeast Guest
Posted: Tue Mar 01, 2011 9:37 am Post subject: Re: hope this helps |
| dualcorebeast wrote: | i am running bots, and my cpu is 100% all the time and i am using 2.93ghz<<< lol 2.94gbs... sorry
Posted: Tue Mar 01, 2011 11:42 am Post subject: |
This java bot stress both cores at 100% ? or only one ?
I'm not an expert in programmable software but in 64bit environment you should check how AMDs with top chipsets are working. _________________ Visit ABC CPU - Virtual CPU Museum. |
