mikedinsb Guest
Posted: Mon May 16, 2011 4:53 pm Post subject: Intel Pentium M 760 VERY unstable fequency |
Hello all! I just bought a laptop off of Craigslist. It is a Lenovo ThinkPad. When viewing YouTube videos or basically any streaming media that CPU is pinned at 100%. I ran CPU-ID and found that the frequency of the cpu was changing very quickly from as low as 400 MHz and all the way up to 4GHz in seconds. I included a CPU-z read out below. All of the different frequencies change including FSB and RAM. Even the VID fluctuates. I went in to the BIOS and disabled all SteedStep features or power saving options too. Does anyone think that the actual CPU could be bad?
Processor 1 ID = 0
Number of cores 1 (max 1)
Number of threads 1 (max 1)
Name Intel Pentium M 760
Codename Dothan
Specification Intel(R) Pentium(R) M processor 2.00GHz
Package (platform ID) Socket 479 mPGA (0x5)
CPUID 6.D.8
Extended CPUID 6.D
Brand ID 22
Core Stepping C0
Technology 90 nm
Core Speed 403.8 MHz
Multiplier x FSB 6.0 x 67.3 MHz
Rated Bus speed 269.2 MHz
Stock frequency 2000 MHz
Instructions sets MMX, SSE, SSE2
FID/VID Control yes
FID range 6.0x - 15.0x
Max VID 1.356 V
Chipset
Northbridge Intel i915GMS/i910GML rev. 03
Southbridge Intel 82801FBM (ICH6-M) rev. 03
Memory Type DDR2
Memory Size 2040 MBytes
Channels Dual
Memory Frequency 134.6 MHz (1:2)
CAS# latency (CL) 4.0
RAS# to CAS# delay (tRCD) 4
RAS# Precharge (tRP) 4
Cycle Time (tRAS) 12 |
Posted: Mon May 16, 2011 11:59 pm Post subject: |
At 4GHz you should smell a fire. To be serious it is impossible to reach that clock.
Is your laptop hangs or restarts ?
Run Orthos (priority 1 for safe test) and check in CPU-Z (latest version) or Everest again. _________________ Visit ABC CPU - Virtual CPU Museum. |
mikedinsb Guest
Posted: Wed May 18, 2011 12:44 am Post subject: no fire yet |
| cpu-z reports it hitting 4 GHz for less than a second and then goes back down to 400 MHz and jumps around every second. Overall is just slow. No complete freezing but hangs. I'll check out what you told me to do a report back. Thanks! |
