athlon pluto and orion cores
skold
PostPosted: Sun May 22, 2005 6:12 am    Post subject: athlon pluto and orion cores Reply with quote
can anyone confirm that the only pluto core athlons are 550-850mhz, while orion cores are 900-1000mhz?
are there any other differences?
PostPosted: Sun May 22, 2005 3:25 pm    Post subject: Reply with quote
What I'm sure :
Athlon Slot A Model 1 : 500-700
Athlon Slot A Model 2 : 550-1000
Athlon Slot A Model 4 : 650-1000
Model 1 : Pluto (i'm not sure)
Model 2 : Orion (i'm not sure)
Model 4 : Thunderbird (i'm sure)
morkork
PostPosted: Sun May 22, 2005 6:22 pm    Post subject: Reply with quote
I can confirm. Athlon K7 is 'Argon', 500 - 650 MHz, 0.25 micron. After switching to aluminum 0.18-micron, six-layer metal manufacturing process the Athlon was called K75 or Modell 2. The K75 was codenamed 'Pluto' for the 550-850 MHz versions and 'Orion' for the 900 - 1000 MHz versions. And AFAIK the Thunderbird was modell 3, not 4, because AMD initially planned to call the XP 'Athlon 4', but dropped it because Intel released the 'Pentium 4'.
..::morkork::..
http://cpu-collection.de
skold
PostPosted: Sun May 22, 2005 6:49 pm    Post subject: Reply with quote
amd did release an athlon 4, but afaik it was only mobile?
http://www.amd.com/br-pt/Processors/ProductInformation/0,,30_118_1276_5889,00.html
PostPosted: Sun May 22, 2005 7:00 pm    Post subject: Reply with quote
Hmm... It's called model 4 in Athlon slot A and Athlon socket A datasheets, and also in Athlon socket A revision guide.
PostPosted: Sun May 22, 2005 7:21 pm    Post subject: Reply with quote
I just remembered - model 3 are first Durons.
skold
PostPosted: Sun May 22, 2005 7:28 pm    Post subject: Reply with quote
i wonder what model 5 and 9 are/were supposed to be?
