VIA C7
PostPosted: Fri May 27, 2005 12:50 pm    Post subject: VIA C7 Reply with quote
Not much info, but still interesting reading:
http://www.via.com.tw/en/products/processors/c7/
Minuteman
PostPosted: Fri May 27, 2005 12:54 pm    Post subject: Reply with quote
Nothing very new under the sun, a slightly changed crappy design is still crap even on a P4 bus :p
I know what I'm talking about Twisted Evil
PostPosted: Fri May 27, 2005 12:55 pm    Post subject: Reply with quote
wow Surprised interesting new model from VIA Tech. Very good relation power consumption to performance.
PostPosted: Fri May 27, 2005 12:58 pm    Post subject: Reply with quote
I guess this is why they called it C7, not C8 Smile
PostPosted: Fri May 27, 2005 1:00 pm    Post subject: Reply with quote
I'll receive a sample soon from VIA. I'll let you know Razz
Minuteman
PostPosted: Fri May 27, 2005 1:01 pm    Post subject: Reply with quote
No, it has an absolutely bad power/consumption ratio compared to a Pentium M. It was an interesting alternative before the P-M, but now it's an useless chip.
Let's test it..but je sens que ça va pas le faire :p
PostPosted: Fri May 27, 2005 1:07 pm    Post subject: Reply with quote
I don't see which model of Pentium M has been compared with VIA C7 1,5 GHz. I think it was identical speed Pentium M 1,5 GHz or maybe I'm in mistake Confused
Minuteman
PostPosted: Fri May 27, 2005 1:12 pm    Post subject: Reply with quote
None at the time, but I tested a C3 Nehemiah 1.2GHz (C5P core) and it has the performance of a PIII 700 and can't be used fanless.
The C7 isn't very different from the C5P core so I don't expect the performance to suddently double...The only place to live for this chip is in embedded applications like micro-ITX mobos.
http://www.x86-secret.com/articles/cpu/c3xl/c3xl-4.htm
chipcollector
PostPosted: Sat May 28, 2005 1:13 pm    Post subject: Reply with quote
Seriously??? Why do you get free samples? Confused
Minuteman
PostPosted: Sat May 28, 2005 1:58 pm    Post subject: Reply with quote
Look at his signature Wink
We are both from x86-secret.com
chipcollector
PostPosted: Sat May 28, 2005 2:02 pm    Post subject: Reply with quote
Oh so you review computer hardware. But that means you need to return the cpu after you finish reviewing it Wink
All hardware review sites receive the test samples but need to return it afterwards. What happens if you don't return it? Laughing
