i try to identify this cpu
cedrik
PostPosted: Mon Nov 28, 2011 2:20 pm    Post subject: i try to identify this cpu Reply with quote
i have the opportunity to buy this cpu but i dont know what is it.. the seller said it's a Pentium 3.. but looks kinda strange.. also he told me that is nothing wrote on it except the thigs in picture..
can someone help me plz?
https://www.facebook.com/CPUCollectionRO
View user's profile Send private message [ Hidden ] Yahoo Messenger
PostPosted: Mon Nov 28, 2011 2:29 pm    Post subject: Reply with quote
It looks like it might be a mobile PIII on an adaptor.
If he cleans off the thermal compound he should see a part number and/or sSpec which would make identification a simple task.
PostPosted: Mon Nov 28, 2011 2:39 pm    Post subject: Reply with quote
It's a mobile Pentium:
http://www.cpu-world.com/CPUs/Pentium/Intel-Mobile%20Pentium%20MMX%20233%20-%20TT80503233%20%28TT233%29.html
cedrik
PostPosted: Mon Nov 28, 2011 2:43 pm    Post subject: Reply with quote
he told me that he cleaned it and isnt any writing ... because it was the first thing i asked ..
i'll buy it and i'll let you know what is it Smile
thank you
cedrik
PostPosted: Wed Nov 30, 2011 10:35 am    Post subject: Reply with quote
It's a SL2N5 Smile
PostPosted: Wed Nov 30, 2011 4:05 pm    Post subject: Reply with quote
PIII mobile CPUs had core on top not on bottom side. This chip reminds me only chinese mobile versions.
cedrik
PostPosted: Wed Nov 30, 2011 4:28 pm    Post subject: Reply with quote
you are suggesting its a fake ?
PostPosted: Wed Nov 30, 2011 4:47 pm    Post subject: Reply with quote
It's not a fake, it's a genuine mobile processor that has been put on an adaptor to use in a socketed system. It's quite common to find those processors on adaptors (as it is with some other QFP and BGA chips).
It's the same as the one Genna showed you, except that yours has a heatspreader on it.
cedrik
PostPosted: Wed Nov 30, 2011 6:19 pm    Post subject: Reply with quote
thank you for the information ..
i have one more question .. the adaptor looks like a Socket 5 adaptor ( only one corner missing pin) .. but i saw here : http://www.x86-guide.com/en/cpu/Intel-Pentium-MMX-120-Mobile-(TCP)-cpu-no2308.html same family cpu mounted in socket 7 .. there were both types of adaptors?
PostPosted: Wed Nov 30, 2011 6:50 pm    Post subject: Reply with quote
both socket 5 & 7 only have the one corner missing
under Intel spec sheet for socket 7.. socket 7 CPUs should have an extra pin so they cant be put into a socket 5 board
but I have yet to see an Intel with the extra pin
but other CPU manufacturers did use the extra pin on their socket 7 processors
PostPosted: Thu Dec 01, 2011 3:58 am    Post subject: Reply with quote
No I mean that was only modification.
cedrik
PostPosted: Thu Dec 01, 2011 4:01 am    Post subject: Reply with quote
my bad ... dont know why, i saw socket 7 and i was thinking at Sk 370 ...
