help identify chip with 6 cores
naked1300
PostPosted: Thu Jan 05, 2012 11:41 am    Post subject: help identify chip with 6 cores Reply with quote
hi,
I know I saw one time this chip here, but I am not able to find
the topic.
Has anyone a info related to these kind of chips? There is nothing
written on the top of the chips.
it seems to be very strange. 6 cores and so less pins??
thx. for your help!
INTEL CPU´s, Peripheral,Ram,Eprom... & many Datasheets @ www.cpu-galaxy.at
silice
PostPosted: Thu Jan 05, 2012 1:11 pm    Post subject: Reply with quote
Hi
Maybe here
http://www.cpu-world.com/forum/viewtopic.php?t=16417
Ross Hyper SPARC
Grey_Traces
PostPosted: Sun Jan 08, 2012 4:27 pm    Post subject: Reply with quote
isa-d wrote:
Ross Hyper SPARC
I have 5 of those chips...I took one apart and they are amazing in the interior!
Did we ever confirm if they are Hyper SPARCs?
naked1300
PostPosted: Sun Jan 08, 2012 4:30 pm    Post subject: Reply with quote
great, I also want to open it and cast in chemical resin. do you have any info for me how to open this chip without damaging the die's?
Grey_Traces wrote:
isa-d wrote:
Ross Hyper SPARC
Grey_Traces
PostPosted: Sun Jan 08, 2012 4:39 pm    Post subject: Reply with quote
Grey_Traces wrote:
isa-d wrote:
Ross Hyper SPARC
I probably did not do it the best way, but I got a fine chisel and put it in a vice clamp. All you need to remove is the metal cap on the top. Since it is plastic, heating it really isn't an option. The cores sit on a thin silicon or metal sheet that is separate from the metal lid/heatsink.
Whatever method you use, try to minimize any dust because the cores have a layer of very sticky gel on top that will attract dust and show any finger prints (permanently).
Hope that helps!
PostPosted: Sun Jan 08, 2012 5:21 pm    Post subject: Reply with quote
Grey_Traces wrote:
isa-d wrote:
Ross Hyper SPARC
Yes, I confirm is a ROSS HyperSPARC
PostPosted: Tue Jan 10, 2012 12:20 am    Post subject: Reply with quote
these will give you a bit more background to them
http://mbus.sunhelp.org/chips/hyperbits.htm
http://mbus.sunhelp.org/modules/index.htm
http://www.cilinder.be/docs/ross/hyper.pdf (477kB)
apart from CPU die not sure which cache or CMTU dies will be on your chips but we ended up with RT626 & RT628s in this GB
