Intel Chip
Robev
PostPosted: Thu Jan 19, 2012 11:33 pm    Post subject: Intel Chip Reply with quote
Can someone identify this Chip for me please?
I have an idea what it is but would like confirmation.
Cheers all. Very Happy
PostPosted: Thu Jan 19, 2012 11:51 pm    Post subject: Reply with quote
guessing will be a C8748 but will need to check further
Robev
PostPosted: Fri Jan 20, 2012 12:21 am    Post subject: Reply with quote
Underside indicates Manufactured 25th week of 1980 in Malaysia...........Cheers
PostPosted: Fri Jan 20, 2012 12:37 am    Post subject: Reply with quote
the 8748 & 8035 use very similar dies.. can you take a pic just of the die?
EDIT >> 8748 & 8035 use the SAME die (die is marked 8748 in both)
Robev
PostPosted: Fri Jan 20, 2012 12:50 am    Post subject: Reply with quote
Hope this will help........Cheers Very Happy
PostPosted: Fri Jan 20, 2012 1:01 am    Post subject: Reply with quote
it is a 8748 die
the stepping info (4642W) tells me it is most likely made as a 8748 part and not 8035
if you can get even closer to the die... i have labelled where the markings are on the die
PostPosted: Fri Jan 20, 2012 1:35 am    Post subject: Reply with quote
Just thought I best clarify this
Intel occasionally labelled 8748s as 8035s.. guessing the eprom memory area was either faulty or they just ignored it in wiring up the die
Elar
PostPosted: Fri Jan 20, 2012 1:37 am    Post subject: Reply with quote
Soviet 8748, very similar die. Maybe it's 8741.
PostPosted: Fri Jan 20, 2012 1:46 am    Post subject: Reply with quote
die matches.. but connection pads around the die dont
here is a die from a D8748
Robev
PostPosted: Fri Jan 20, 2012 2:06 am    Post subject: Reply with quote
This as good as I can get at this time Confused
PostPosted: Fri Jan 20, 2012 2:15 am    Post subject: Reply with quote
just had a look.. even thou 8748 & 8741 seem to have same die (but diff connection pads).. the 8741 die is marked as such and in different position
where the 8741 part number is located.. the 8748 has additional circuitry filling some of the empty space
Robev
PostPosted: Fri Jan 20, 2012 3:00 am    Post subject: Reply with quote
Had another go, don't know if this will help though
PostPosted: Fri Jan 20, 2012 3:05 am    Post subject: Reply with quote
8748 die with 1978 copyright
Robev
PostPosted: Fri Jan 20, 2012 3:29 am    Post subject: Reply with quote
Thanks for that Very Happy
I thought it was a microcontroller just wasn't sure which one......Cheers
