zburget
Joined: 13 Mar 2012 Posts: 596 Location: Czech Republic
Posted: Tue Mar 13, 2012 4:58 pm Post subject: Help with identifying CPU - I |
I found a home in a box of poorly identifiable processor.
This is definitely the 486 CPU, but this version isn't in your catalog:
| Code: | | http://imageshack.us/photo/my-images/708/unknowniiib.jpg/ |
Detail of the inscription on the bottom:
| Code: | | http://imageshack.us/photo/my-images/571/unknowniiic.jpg/ |
On the two sides are glued labels. On one is difficult to see, but clearly readable number 622603-001.
On the other is very difficult to read type code (about): INTEL486(TM)DX2-66SL. Sticker I scanned and modified to be what most readable text:
| Code: | | http://imageshack.us/photo/my-images/576/unknowniiid.jpg/ |
Does anyone know exactly what processor is it? Is this a boxed type or is it only cooler glued to the "normal" processor and it would be better to try to unstick it? |
Robev
Joined: 10 Mar 2006 Posts: 3693 Location: New Zealand
Posted: Tue Mar 13, 2012 5:02 pm Post subject: |
I would say it was a standard A80486DX2-66
Cheers _________________ The Older they are the Better they are. |
Posted: Tue Mar 13, 2012 7:54 pm Post subject: |
I agree with Rob. A lot of system manufacturers used aftermarket heatsinks. remove the heatsink and you should see a regular 486.
Also, instead of enclosing the image url in the "code" identifiers, use "[img]". Also, use the "direct" link frmo imageshack, and not the "link" url, then you can embed the pics:
 _________________ My graphics card database can be found at http://www.gpuzoo.com.
Posted: Tue Mar 13, 2012 8:32 pm Post subject: |
I agree. It should be an SL-enhanced version of A80486DX2-66
Posted: Wed Mar 14, 2012 8:16 am Post subject: |
i apologize for improperly inserted links. This forum allowed me to only 3 links for the post. Direct links, I did not want to give because of the size of images. If this is not a problem, so I'll do it next time.
Otherwise - I see that there are real experts - the removal of standard heatsink showed A80486DX2-66. S-Spec code was only just before - SX807.
thanks to all |
