Intel P5's, Understanding Part #'s?
Redeyeburn
PostPosted: Fri Apr 06, 2012 12:12 am    Post subject: Intel P5's, Understanding Part #'s? Reply with quote
Been trying to figure out the difference in these type's of cpu's that have the same sSpec, but one has a dash (-) in the part number, the other has no dash.
Example, Intel -
A8050275 SX969
A80502-75 SX969
Anyone know what the difference is besides the obvious?
I'm trying to figure out from a collector's point of view, if I should be collecting the 2 different samples of each sSpec, or if only some of these cpu's have the 2 versions?
Thanx all.
Wanted: Grey trace Intel 4004 (mala), will give grey trace and white Microsystems International MIL MF8080, PM me if interested.
PostPosted: Fri Apr 06, 2012 12:28 am    Post subject: Reply with quote
It's the same chip, the difference is only in the part number. More information is here:
http://www.cpu-world.com/forum/viewtopic.php?t=4453
Chook
PostPosted: Fri Apr 06, 2012 3:48 am    Post subject: Reply with quote
Intel had a habit of changing their part numbering style at random.
Hence why the earlier 486 Overdrives were labelled the same as the chip they were designed to replace only with ODP at the beginning. So if you had a 486SX-25 you got the ODP486SX-25 overdrive. If you had a DX-25 you got the ODP486DX-25. Then not long after, Intel changed their mind and labelled the chip as DX2ODP50 and marketed it as replaceing both the SX-25 and DX-25. Probably because people (like myself!) looked at the ODP486SX-25 and thought, that's not overdrive, its only second gear!
Other changes include the dash as you pointed out, and the 'Processor' marking on early socket 4 Pentiums. Neon_WA is the expert on such things, he has worked out almost the exact date Intel made these changes.
Pentium 4s also have several different styles. Large logo, small logo and no logo at all.
General failure reading disk in drive A
Who's General Failure and why is he reading my disk?
PostPosted: Fri Apr 06, 2012 7:12 pm    Post subject: Reply with quote
for Pentiums.. the dash was removed from part number around week 46 1995
change from TM to R was around week 28 1995
change from iComp to iComp2 was week 41 1996
