White ceramic DIP
PostPosted: Fri May 04, 2012 1:04 am    Post subject: White ceramic DIP Reply with quote
anyone recognise this package in either a CPU or non CPU.. trying to identify a possible faked processor
I have airbrushed out the possible remarked markings
Chiefish
PostPosted: Fri May 04, 2012 6:14 am    Post subject: Reply with quote
Looks like this tty chip I have, Doesnt look like an intel package either.
PostPosted: Fri May 04, 2012 6:25 am    Post subject: Reply with quote
Cheers Carl Smile
knew I had seen it before
Chiefish
PostPosted: Fri May 04, 2012 6:54 am    Post subject: Reply with quote
Now Im curious as to what was marked on it.
PostPosted: Fri May 04, 2012 7:17 am    Post subject: Reply with quote
I want to talk to the seller first and find out some history of where he sourced the chip.
but if no luck in finding will post anyway
Chiefish
PostPosted: Fri May 04, 2012 7:23 am    Post subject: Reply with quote
No problem, I am just curious anyway. Wink
PostPosted: Fri May 04, 2012 10:48 am    Post subject: Reply with quote
6502 or 8080...?
jrmunro
PostPosted: Fri May 04, 2012 2:34 pm    Post subject: Reply with quote
Most likely a UART if says TTY on it like this one
wepwawet
PostPosted: Fri May 04, 2012 4:00 pm    Post subject: Reply with quote
I have a NS SC/MP II with exactly that package type.
You may use the photos I have posted here under CC BY-NC-SA license.
PostPosted: Fri May 04, 2012 8:34 pm    Post subject: Reply with quote
kosmokrator wrote:
6502 or 8080...?
a few had guessed or saw the listing
a MOS MCS 6502
PostPosted: Sat May 05, 2012 6:20 am    Post subject: Reply with quote
poor printing :/ .....
never Seen this Package on 6502 before ....
Maybe real ..may not
Robev
PostPosted: Sat May 05, 2012 6:46 am    Post subject: Reply with quote
Confused and the verdict is Question
PostPosted: Sat May 05, 2012 10:14 am    Post subject: Reply with quote
probably will never know as seller has no facility to test.. unless you want to buy n try Laughing
Robev
PostPosted: Sat May 05, 2012 3:34 pm    Post subject: Reply with quote
IMHO the markings look genuine enough but as you say the proof would be in the pudding Laughing
