ccsolutions
Posted: Wed May 09, 2012 10:03 am Post subject: Does anyone have an engineering contact inside Intel? |
| We have a high end Xeon CPU with a capacitor that was broken off the bottom. We know of a shop that can repair it but they need to know the rating. Does anyone have a contact inside Intel that would be able to look at the schematics? Please send PM if you do. We will gladly compensate if it works out. |
joekster
Joined: 12 May 2011 Posts: 100 Location: Palm Beach, Florida USA
Posted: Wed May 09, 2012 1:02 pm Post subject: |
| Chances are, if its just one, it'll work just fine. If you really had to (or wanted to replace), I would unsolder one and check the capacitance. The voltage should be the same as the core (but always get a cap rated at >20% of the voltage). |
ccsolutions
Posted: Fri May 11, 2012 10:24 am Post subject: |
Thanks but we're not even sure of the exact size. If we knew the exact part to get, it would be much easier.
| joekster wrote: | | Chances are, if its just one, it'll work just fine. If you really had to (or wanted to replace), I would unsolder one and check the capacitance. The voltage should be the same as the core (but always get a cap rated at >20% of the voltage). |
mavroxur
Posted: Fri May 11, 2012 12:21 pm Post subject: |
| ccsolutions wrote: | Thanks but we're not even sure of the exact size. If we knew the exact part to get, it would be much easier.
If you could take one adjacent one off and measure it with a capacitance meter, you'd have an idea of the value. When he said "size", he was refering to the value. If you knew the value, voltage, and the physical size, one visit to Mouser Electronics would get you what you needed, guaranteed. |
