Silver AMD X5-133
PostPosted: Thu Jul 14, 2005 1:39 pm    Post subject: Silver AMD X5-133 Reply with quote
Good thing I was sitting when I found this processor in a lot of chips:
It looked so cool... and then I turned the processor and saw normal ceramic on the back Sad I think somebody used Arctic Silver or other silver-based thermal paste on this chip.
Genna
skold
PostPosted: Thu Jul 14, 2005 4:34 pm    Post subject: Reply with quote
lol, you should put it in a rubbing alcohol bath Wink
PostPosted: Fri Jul 15, 2005 3:54 am    Post subject: Reply with quote
Laughing I had the same. I bought Pentium 150 silver Wink
PostPosted: Fri Jul 15, 2005 6:30 am    Post subject: Reply with quote
Try artic silver on a Pentium Pro.
You will NEVER remove the thermal paste again.
Seems to be some physical reaction between the CPU package and the artic silver
PostPosted: Fri Jul 15, 2005 1:39 pm    Post subject: Reply with quote
hehe Wink you are in mistake. I clear and no silver on cpu - you must use extract petrol ( in Poland this named as "benzyna ekstrakcyjna")
