If you buy something through eBay links below we may earn a small commission.
This will not cost you extra, and it will help us to keep the forum
operational and ad-free.
gg1978
Joined: 31 Jul 2012 Posts: 1052 Location: Indiana, USA
Posted: Tue Jul 31, 2012 11:29 pm Post subject: how to take best pictures of CPUs?? |
I've been collecting for quite some time now. I've never gone to the trouble of photographing any or all of my CPU collection, but seeing all the nice collections around here has changed my mind on that.
It appears to me that most people seem to be taking pictures with the flash turned off otherwise it washes out the CPU markings. Other than that, any other tips?
As for what i like to collect, pretty much every type of CPU. I favor the Intel PPro and DEC Alpha series of CPU's, but there are others that are neat as well!!!
My first picture will be of my SL2FJ Pentium Pro 166/512K that i've had for about 10 years now.. I never got the box for it, unfortunatly, but it's neater to see outside the box anyway Looks like it was well worth buying back then though.. |
Posted: Tue Jul 31, 2012 11:35 pm Post subject: |
plenty of natural diffused light will help.. especially if camera has a automatic focus
most automatic cameras have quite a bit of difficulty focussing in low light conditions
If you cant rely of natural light then worth making up a photo booth with lights behind diffusers
very nice Pro you have there.. only know of 4 others in collections..and 3 of those are in sealed boxes _________________ There are 10 types of people in this world:
Joined: 15 Mar 2005 Posts: 2214 Location: Karlskrona, Sweden
smithy
Joined: 27 Apr 2008 Posts: 2906 Location: Sydney, Australia
Posted: Wed Aug 01, 2012 6:27 pm Post subject: |
I use a Kaiser Reprokid Copy Stand, which is small flat table with a vertical arm which the camera attaches to (so a form of tripod i guess). You can move the arm up or down to get different distances away from the item you are photographing, plus it has two lights. I use manual setting on the camera - manual focus (as the vertical arm has cm graduations, so i know exactly how far away it is), no flash, 2 sec timer, and exposure compensation.
Much slower than a scanner, but you get decent results _________________ My former Intel collection:
www.smithschips.com.au |
gg1978
Posted: Wed Aug 01, 2012 11:20 pm Post subject: |
Well hopefully with a bit more light i'll be able to get better results. Much better than using the camera in my phone though that's for sure  |
sherwoods12
Posted: Sun Aug 05, 2012 10:18 pm Post subject: |
| I used a scanner for most of mine with excellent results. |
UMMR
Joined: 23 Aug 2007 Posts: 381 Location: Udine, ITALY
Posted: Tue Aug 07, 2012 8:20 am Post subject: |
| sherwoods12 wrote: | | I used a scanner for most of mine with excellent results. |
Hello,
my old and inexpensive HP ScanJet 5300C works very well even with cards and boards, not only CPUs, since it has a decent DOF (Depth Of Field). My favourite camera is the old Nikon Coolpix 5000 with its excellent ability of manual focusing down to 8 mm. Unfortunately I have to work with no more than 200 ISO in order to avoid noise...
I also tried a Fuji S9500 with excellent results.
FYI I work only with natural or diffused illumination, never with the camera's flash.
Your PPro is nice...
Paolo |
gg1978
Posted: Thu Aug 09, 2012 10:55 am Post subject: |
Well i was using my couch in the living room, i'm sure the lighting isn't quite optimal I did use the macro mode of my camera to get the text at least somewhat sharp though. I do have a scanner, pretty new, but not sure what kind of sensor it uses.. |
