Plastic Intel 386DX-33?
iulianv
PostPosted: Tue Aug 21, 2012 4:07 am    Post subject: Plastic Intel 386DX-33? Reply with quote
Did such a CPU exist? I can't seem to find any "documented" reference about it...
http://www.ebay.com/itm/Vintage-Intel-80386-386-CPU-Processor-80386DX-33-SX692-on-adaptor-/200809143966?pt=UK_VintageComputing_RL&hash=item2ec1285e9e
(NG80386DX-33 L2483644 SX692)
Robev
PostPosted: Tue Aug 21, 2012 5:33 am    Post subject: Reply with quote
Yes it sure did & does
Here is the short form datasheet
NG80386DX33
Intel
Search: NG80386DX33
32-Bit Microprocessor - Flexible 8,16,32-Bit Data type
Clock Frequency - Max. (Hz)=33.3M
Clock Frequency - Min. (Hz)=8M
Min Instruction Length (bits)=8
Max Instruction Length (bits)=32
Memory Addressing Range=4G
Number of Addressing Modes=11
Interrupt Types=Int/Ex Vec
Number of Interrupt Lines=2
Number of Maskable Interrupts=1
No. of Non-Maskable Interrupts=1
Vsup Nom.(V) Supply Voltage=5
Package=PGA
Pins=132
Military=N
Technology=CMOS
you can find the full datasheet here
http://www.datasheetarchive.com/
just type in the code "ng80386dx33" into the search box Smile
