www.cpu-info.com, 39 new CPU's/FPU's added
Post new topic   Reply to topic    CPU-World.com forums Forum Index -> News
Simmayor
PostPosted: Sun Jul 31, 2005 7:05 am    Post subject: www.cpu-info.com, 39 new CPU's/FPU's added Reply with quote
Hi all,
I finally had some time to add all the CPU's and FPU's i collected the last few month's. The are some really nice pieces :
- Cyrix Cx486DX2-V66, QFP on PCB
- NexGen Nx586-P80 with double print
- Intel Pentium 80503-133MHz, PPGA
- Two Kingston 286 to 386 upgrade boards
- It's ST 486DX4-75
and many more
Please drop by and have a look, www.cpu-info.com
Simmayor
PostPosted: Sun Jul 31, 2005 3:17 pm    Post subject: Reply with quote
Nice update! I like CCCyrix, ST 486DX4-75 and Nexgen P80.
PostPosted: Sun Jul 31, 2005 4:32 pm    Post subject: Reply with quote
I didn't knew there was ST 486DX4-75 ! Shocked
Maybe there are Cyrix 486DX4-75 too ?
Simmayor
PostPosted: Mon Aug 01, 2005 1:00 am    Post subject: Reply with quote
As you can see from my avatar the CCCyrix is my Precious!
When i found the It's 486DX4-75, i couldn't believe my eyes. Shocked Because i also hadn't seen that speed grade before.
It came from a box full of 486 CPU's, lucky me for deciding to sort the whole box after all.
As for the possibility of a Cyrix 486DX4-75, i also have a IBM 486DX4-75. Weren't these all of the same design? In that case a Cyrix will pop up sooner or later.
Simmayor
PostPosted: Mon Aug 01, 2005 2:12 am    Post subject: Reply with quote
the DX4-75s are rather nice, I found this one years ago.
http://www.cpushack.net/gallery/showimg.php?file=/chippics/ST/ST486DX4V75HS.jpg
IBM DX4-75s are what Cyrix rated at 100 so it is doubtfull you will find a Cyrix 75 (though a ES may appear Smile)
Post new topic   Reply to topic    CPU-World.com forums Forum Index -> News All times are GMT - 5 Hours
