marty Guest
Posted: Sun Aug 14, 2005 1:27 pm Post subject: AMD 266MHz MMX Socket 7 CPU voltages |
Hi all,
I bought a Panel PC recently which has a motherboard supporting the following:
133,166 & 266 clock speeds
2.5 & 3.3V I/O
1.9, 2.45 & 3.1V Core
I've found it hard to get a CPU matching these specs.
I considered the AMD 266 as it has 3.3V I/O but 2.2V Core.
Would setting to 2.45V core sizzle it???
Many thanks |
Posted: Sun Aug 14, 2005 6:40 pm Post subject: |
I think many 2.2V K6-2 processors will work fine at 2.45V. If you already have K6-2 266 processor then try to put it into motherboard. If the system freezes while booting or when you use CPU-intensive programs (for instance games) then try to use better heatsink/fan, or put an extra fan in your computer case.
