What happens in these CPU ?
todayisme2000
PostPosted: Mon Dec 24, 2012 8:39 am    Post subject: What happens in these CPU ? Reply with quote
(A) The chip top side possession by wire
(B) Text has been clean
(C) The chip top side is painted green
PostPosted: Mon Dec 24, 2012 9:08 am    Post subject: Reply with quote
A) I don't know
B) maybe official remarked by AMD for some reason we don't know.
C) maybe for protection purpose
Merry X'mas
gctfinder
PostPosted: Mon Dec 24, 2012 9:17 am    Post subject: Reply with quote
A) thermal sensor ?
PostPosted: Mon Dec 24, 2012 9:32 am    Post subject: Reply with quote
a) thermal sensor /testing
b) officially remarked some es maybe
c) officially remark ... or is just the extra coating use in military boards applications.. can easy go with a thin razor or Alcohol
susl45
PostPosted: Mon Dec 24, 2012 9:37 am    Post subject: Reply with quote
C) anti-water gule/layer, and often used for military chips or board.
Trade list
http://www.cpu-world.com/forum/viewtopic.php?t=15832
PostPosted: Mon Dec 24, 2012 11:40 am    Post subject: Reply with quote
C) conformal coating, mainly prevents moisture damage and stops whisker growth/damage from tin wiskers. Very important. Some is silicon based which you have to use special chemicals to remove. (like tetrafuran)
todayisme2000
PostPosted: Tue Dec 25, 2012 6:28 am    Post subject: Reply with quote
OK, I understand.
Thank thank you very much.
