Lucas Guest
Posted: Wed Dec 26, 2012 7:34 pm Post subject: Intel ' 05 Q6600 |
Hey guys,
Will my Intel core 2 Quad
2.4Ghz be compatible with a LGA775 Socket ?
Im getting this motherboard to build a media pc
Fatal1ty F-I90HD
Im planning on having a 2.5" possibly a 3.5" around 250 - 500GB
the board has a HDMI output so no graphics card
Intel Core 2 Quad Q6600 Processor
4GB RAM
iHas burner
What power supply do you recommend ?
Would a 350W be ok ?
Cheers
- Luke
[/list]
http://www.cpu-upgrade.com/mb-ABIT/Fatal1ty_F-I90HD.html |
Posted: Thu Dec 27, 2012 12:55 pm Post subject: |
ATI Radeon Xpress 1250 (chipset of your motherboard) support Q6600 so it should work.
Branded 350W will be enough i.e. Fortron, Enermax, Tagan, Chieftec with strong +12V line. _________________ Visit ABC CPU - Virtual CPU Museum. |
Lucasaee Guest
Posted: Thu Dec 27, 2012 4:26 pm Post subject: |
Thanks for the reply
Think I will go for a cheap 400W then, on a budget ! |
