100% fan speed... Help!
Karasunaki
PostPosted: Tue Aug 30, 2005 9:35 pm    Post subject: 100% fan speed... Help! Reply with quote
Hi everybody!
When I play a game my CPUfan is going at 100% Does anyone know why its doing that...??
It's very annoying to here the fan when playing =) so please can anyone tell me what's wrong!
PostPosted: Wed Aug 31, 2005 12:49 am    Post subject: Reply with quote
It is nothing wrong. The CPU gets very hot when playing and need to be cooled. Are you shure it is the CPU fan? The graphiccard fans are almost always very noisy.
Open your computer and listen from where the noise comes and replace it with a less noisy one. There are plenty of alternatives.
Here you can find fans that are very quiet http://www.zalman.co.kr/
/Thomas
PostPosted: Wed Aug 31, 2005 5:34 am    Post subject: Reply with quote
I like buying coolers in econo/power segment. So I can prefer Arctic coolers : http://www.arctic-cooling.com or Pentagram coolers : http://www.pentagram.com.tw
Karasunaki
PostPosted: Wed Aug 31, 2005 6:58 am    Post subject: Reply with quote
I will check that! Anyone using watercoolant?? How good is it and do you have to change the water often?
faraz
PostPosted: Tue Nov 29, 2005 12:47 am    Post subject: Reply with quote
I have almost same problem.When i play cricket2004.My PC get stuck.Can anyone tell me wats the problem ??
slava
PostPosted: Tue Nov 29, 2005 3:36 am    Post subject: Reply with quote
Try removing your processor cooler and changing the thermal grease under it. Or just clean the cooler of the dust. Should help.
Collecting soviet and western CPUs once again -- highfive to old-timers o/
PostPosted: Tue Nov 29, 2005 10:28 am    Post subject: Reply with quote
Hehe... I checked my cooler and it was thick with dust Very Happy Cleaned it and almost silent... Thanks all
