PowerLeap CPUs -> Prescotts replacing Northwood cores
Whatzupyoung
PostPosted: Wed Aug 31, 2005 7:23 pm    Post subject: PowerLeap CPUs -> Prescotts replacing Northwood cores Reply with quote
If you check out www.powerleap.com's site, they claim to be able to convert a Prescott core CPU such that it can be installed on boards that only accept Northwoods. Has anyone out there ever installed one of these? Did it work? I love the idea, it gives me more and better upgrade options, but only if it'll work.
PostPosted: Thu Sep 01, 2005 1:17 am    Post subject: Re: PowerLeap CPUs -> Prescotts replacing Northwood cores Reply with quote
Powerleap made converters which are always work as description says. I think you can buy it safe Smile
