Intel CPU identification
Kev Vader
PostPosted: Wed Jul 10, 2013 6:32 pm    Post subject: Intel CPU identification Reply with quote
Hi All, I am (again) at a loss when identifying a CPU.
The only identifying marks on the CPU are:
3134A087-0549
4134A258
PostPosted: Wed Jul 10, 2013 6:39 pm    Post subject: Reply with quote
guessing P3 (not a P2) Xeon
without plastic cover will be hard to work out speed or sSpec
Chook has a large selection of naked Xeon slots.. so he maybe able to identify at least cache size
PostPosted: Wed Jul 10, 2013 6:40 pm    Post subject: Reply with quote
Looks like PIII Xeon Cascades 1 or 2 Mb "5/12V".
For exact freq. you should test it.
Exact Sspec is often impossible to determine, only indirectly by CPUID.
Chook
PostPosted: Wed Jul 10, 2013 8:44 pm    Post subject: Reply with quote
Its a 2MB Xeon with on die cache, so it would be either a 700/100/2M or a 900/133/2M.
General failure reading disk in drive A
Who's General Failure and why is he reading my disk?
Kev Vader
PostPosted: Thu Jul 11, 2013 12:50 am    Post subject: Reply with quote
Chook
PostPosted: Thu Jul 11, 2013 12:58 am    Post subject: Reply with quote
Something I haven't checked is whether the 2.8 volt Xeons look different inside to the 5/12 volt versions.
PostPosted: Thu Jul 11, 2013 1:06 am    Post subject: Reply with quote
They should
PostPosted: Thu Jul 11, 2013 1:09 am    Post subject: Reply with quote
Chook, how do you know it's not a 1Mb one? Smile
Chook
PostPosted: Thu Jul 11, 2013 10:39 am    Post subject: Reply with quote
I had another look at my Xeons and you are right. It could also be a 700/100/1M. There is no difference. There also does not appear to be a difference between 2.8 and 5/12 volt varieties.
