Intel ES identification
PostPosted: Tue Aug 27, 2013 2:11 pm    Post subject: Intel ES identification Reply with quote
I have 2 different ES, with some information about each. I cannot test them. Please contribute additional information.
First is Q0FG
CM80623B2072602
socket 1155
This is included in the big list of Q-Specs that Neon_WA posted 3 years ago. Thanks for posting the list - it is helpful. Smile The list says it is Sandy Bridge -HE-4 so I think this means 4-core, but is there any way to determine which product, speed, caches, etc.?
http://www.cpu-world.com/forum/viewtopic.php?t=15377&highlight=q0fg
Second is socket 1156, and has only hand-written markings:
Cu-D (?) C0
Q2X6
11851
3.2 GHz
So I think Q2X6 is a Q-Spec and C0 is silicon revision. It seems likely Clarkdale, but again is there any way to determine which product - Xeon, Core i5, Core i3?
PostPosted: Tue Aug 27, 2013 4:32 pm    Post subject: Reply with quote
I don't think it's possible to determine Q0FG specs (the number of cores, frequency, etc) without testing it. Fortunately, it was already done:
http://www.xfastest.com/forum.php?mod=viewthread&tid=64068&page=4#pid362447
I will add it to the S-Spec database once I have a new version of the S-spec build script ready. The script should be ready this weekend or next week.
PostPosted: Tue Aug 27, 2013 10:41 pm    Post subject: Reply with quote
Thanks for the info. So, Q0FG is a Core i7 4-core @2.5 GHz with 6MB L3 cache, 206A2 B2
PostPosted: Tue Aug 27, 2013 11:59 pm    Post subject: Reply with quote
Yes. Some sellers on eBay sold it as "underclocked i7-2600K" Smile
http://www.ebay.com/itm/Intel-Core-i7-2600k-Underclocked-2-50GHz-6m-5-0GTs-Q0FG-CPU-Processor-Quad-1155-/281148627243
