Phenom X4 9850
Chaya
PostPosted: Sun Oct 20, 2013 3:52 pm    Post subject: Phenom X4 9850 Reply with quote
Is there any difference between AMD Phenom X4 9850 (95w) and the Phenom X4 9850B? I been doing Google searches, but either there's no difference, or I'm not asking the right question!
vezhlys
PostPosted: Sun Oct 20, 2013 5:41 pm    Post subject: Reply with quote
There is no difference afaik. B just means business class and these CPUs had a longer lifespan than consumer parts. Specifications matched between them.
http://picasaweb.google.com/vezhlys/CPUsCollection
mavroxur
PostPosted: Mon Oct 21, 2013 12:14 am    Post subject: Reply with quote
I believe the 9850B isn't unlocked. Also, the TDP is lower on the 9850B.
PostPosted: Mon Oct 21, 2013 12:53 am    Post subject: Reply with quote
There are some minor differences in the core voltage and TDP in the minimum performance state, otherwise they are identical:
http://www.cpu-world.com/Compare/223/AMD_Phenom_X4_9850_%2895W%29_vs_AMD_Phenom_X4_9850B.html
Chaya
PostPosted: Mon Oct 21, 2013 8:26 pm    Post subject: Reply with quote
So guess if I get a choice, it sounds like the 9850B is a bit better for longevity.
Thanks to all that responded!
