cedrik
mavroxur
Posted: Tue Dec 17, 2013 3:16 pm Post subject: |
| Maybe a hardened 386? Not sure.. |
Posted: Tue Dec 17, 2013 3:21 pm Post subject: |
| funny heat sink.........indeed..... |
cedrik
Posted: Tue Dec 17, 2013 3:30 pm Post subject: |
yes try with some thin screwdriver in the corners I see there is some space to put the screwdriver try to push a bit....
but even broke for sure we see what is ,,,
not a big deal in a case of 386 chip imo |
mavroxur
Posted: Tue Dec 17, 2013 4:41 pm Post subject: |
| kosmokrator wrote: | yes try with some thin screwdriver in the corners I see there is some space to put the screwdriver try to push a bit....
That, or grind the edge thin and peel it away from the chip around the edges. Will destroy the heatsink, but would reduce the risk of cracking the chip. |
cedrik
Posted: Tue Dec 17, 2013 4:46 pm Post subject: |
i try gentle with a small screwdriver in the corners but no luck ... i dont dare to try harder... and i dont wanna destroy the heatsink ... it looks kinda cool this way... to bad that printings on it are that bad  _________________ https://www.facebook.com/CPUCollectionRO |
Posted: Tue Dec 17, 2013 5:23 pm Post subject: |
| mavroxur wrote: | | kosmokrator wrote: | yes try with some thin screwdriver in the corners I see there is some space to put the screwdriver try to push a bit....
if is aluminum this heatsink I think this method is the best ,,,, try to bent with some hard tool the heatsink around the chip corners and the chip will come off easy....
if is harder metal no idea...... |
Posted: Tue Dec 17, 2013 8:46 pm Post subject: |
think says
Malaysia
9145...... so week 45 1991
598?181
think AMD looking markings
did it come out of a printer? _________________ There are 10 types of people in this world:
mavroxur
Posted: Tue Dec 17, 2013 10:14 pm Post subject: |
| I think slowly grinding down the perimeter with a bench grinder (SLOWLY) until there's not much metal left, and then gently bend it away from the chip on all four sides, would allow you to lift the chip out safely, assuming it's not epoxied in too bad. |
cedrik
Posted: Wed Dec 18, 2013 2:37 am Post subject: |
| Neon_WA wrote: | think says
Malaysia
598?181
did it come out of a printer? |
i dont know where it came from ....
thank you for your answers...
later today (9:30 a.m. here) i'll try to open it _________________ https://www.facebook.com/CPUCollectionRO |
ovidiuanghel
Posted: Thu Dec 19, 2013 10:30 am Post subject: |
So....Cedrik, this is your chip, do you want it back ?  |
cedrik
Posted: Thu Dec 19, 2013 10:48 am Post subject: |
im kinda dissapointed... i was hoping that it's something weird..special ...i guess i already have this one  _________________ https://www.facebook.com/CPUCollectionRO |
