IBM 33G0396
cedrik
PostPosted: Fri Jan 17, 2014 5:12 am    Post subject: IBM 33G0396 Reply with quote
Hello
I have this 2 chips...
Here http://www.cpu-world.com/forum/viewtopic.php?t=8762&highlight=33g0396 there were opinions that this seems to be 486 CPUs..
Can someone tell me for sure what they are?
Thank you
https://www.facebook.com/CPUCollectionRO
View user's profile Send private message [ Hidden ] Yahoo Messenger
Komz
PostPosted: Fri Jan 17, 2014 5:26 am    Post subject: Reply with quote
For sure it is IBM cpu Smile I bet on 486SLC2 50 MHz
http://muzeumprocesorow.pl
https://www.facebook.com/muzeumprocesorow
Elar
PostPosted: Fri Jan 17, 2014 5:44 am    Post subject: Reply with quote
Earlier discussion: http://www.cpu-world.com/forum/viewtopic.php?t=8819&view=next
cedrik
PostPosted: Fri Jan 17, 2014 6:00 am    Post subject: Reply with quote
yes, i read it ,i also quoted that topic.. but the ideea there was :
- it looks like
- seems to be
- the seller said it's ..
i wanted to know if meanwhile new informations about them are available just to be sure what they are..
thank you
Elar
PostPosted: Fri Jan 17, 2014 11:02 am    Post subject: Reply with quote
Sorry, didn't notice the link. Concentrated on picture Smile
PostPosted: Fri Jan 17, 2014 7:53 pm    Post subject: Reply with quote
its the daughter (processor) board for the IBM Thinkpad 720C
The processor will be a 50MHz 486SLC2 (25MHz FSB, Vcore 3.3V, TDP 2.3W)
they should have a connector to fit the J15 connector on the main board
cedrik
PostPosted: Fri Jan 17, 2014 7:57 pm    Post subject: Reply with quote
thank you very much... now i know for sure Smile
PostPosted: Fri Jan 17, 2014 8:05 pm    Post subject: Reply with quote
just looked at old post.. Elar had it covered back then
With these sort of things always best to search for the board FRU
say if the 486 was de-soldered from board.. it becomes almost impossible to work out what they are
