Vegeta
Posted: Wed Jul 16, 2014 1:28 pm Post subject: Unknown IBM chips |
I can not find any information about these chips. What's this?
IBM 70P5381 СLGA-1247
IBM 06K7145/06N4267 СCGA-1247
IMB 18K0080/29K4314 СCGA-1678 _________________ Wanted: 4 x VT-25-A tubes |
Vegeta
Posted: Wed Jul 16, 2014 1:57 pm Post subject: |
IMB 18K0080/29K4314 СCGA-1678 similar to POWER3-II? _________________ Wanted: 4 x VT-25-A tubes |
Posted: Wed Jul 16, 2014 2:16 pm Post subject: |
1) it's a support chip
2) one way RS-64 III
3) Power 3 II |
Vegeta
Posted: Wed Jul 16, 2014 2:23 pm Post subject: |
Thank you!
Advice please how to remove of compound traces from ceramic borders? For example like this Power 3 II. _________________ Wanted: 4 x VT-25-A tubes |
Vegeta
Posted: Wed Jul 16, 2014 4:40 pm Post subject: |
My RS-64 III are 06K3016 and 06K3017, RS-64 IV are 57P5492 and 73H3708
and I'm sure of these part numbers because I personally pull out the CPUs from the boards
so seem part numbers with K are RS-64 III (part numbers changes for the speed and number of cores) and part numbers with P and H are RS-64 IV |
aberco
Joined: 05 Sep 2013 Posts: 2655 Location: Paris France
Vegeta
Posted: Thu Jul 17, 2014 1:56 am Post subject: |
Thanks for the info guys!  _________________ Wanted: 4 x VT-25-A tubes |
henriok
Joined: 30 Dec 2007 Posts: 157 Location: Gothenburg, Sweden
Posted: Thu Jul 17, 2014 12:13 pm Post subject: |
Cool! I'd very much appreciate a high res photo of the RS64-III. If you could get the text on the die, that'd be awesome! _________________ Always on the look out for POWER, PowerPC and Power Architecture information. For photographs, information and parts to buy. Am doing research at Wikipedia |
Vegeta
Posted: Thu Jul 17, 2014 12:19 pm Post subject: |
| henriok wrote: | | Cool! I'd very much appreciate a high res photo of the RS64-III. If you could get the text on the die, that'd be awesome! |
Give me your e-mail in PM. I'll send hi-res scan.
It's RS64-III "IStar" 600MHz imho _________________ Wanted: 4 x VT-25-A tubes |
henriok
Posted: Thu Jul 31, 2014 11:37 am Post subject: |
So I got more pictures from isa'd, and I must come to the conclusion that the middle one is a RS64-IV (I've outlined it in red in my picture).
It got smaller dies than the other RS64-III's. It's got identical capacitor layout and markings on the ceramic, as the other RS64-IV SCM, and the same size die. _________________ Always on the look out for POWER, PowerPC and Power Architecture information. For photographs, information and parts to buy. Am doing research at Wikipedia |
Vegeta
Posted: Thu Jul 31, 2014 3:20 pm Post subject: |
They both RS64-III "IStar" and RS64-IV started in 2000 by SOI process, so they may have identical capacitor layout and markings on the ceramic? On the other hand, they are similar Part Numbers, the same as in RS64-III "06K..." May be RS64-III "IStar" and RS64-IV produced by similar 0.18 SOI process? Thus the die RS64-III "IStar" 0.18 is less than at RS64-III "Pulsar" 0.22 According to my measurements a die size 06K7145 of 132 mm2. RS64-III die size of 140 mm2, RS64-IV was 128 mm Information on the RS64-III "IStar" almost no It is known that 06K7145 is 600Mhz (John pull it from 600MHz processor board) and statistics from isa-d (all pn "06K..." is RS64-III) Although it may you are right.
Sorry for my google-translate
On photo die of RS64-IV only for info, taken from article by J. M. Borkenhagen R. J. Eickemeyer "A multithreaded PowerPC processor for commercial servers" © 2000 IBM This paper describes the microarchitecture of the RS64 IV, a multithreaded PowerPC _________________ Wanted: 4 x VT-25-A tubes |
aberco
Posted: Thu Jul 31, 2014 4:32 pm Post subject: |
Cool, that's some very nice piece of information
The FRU on the die must help too?
I have some RS64 boards from BULL RS6000 clones that I will photograph and post here. |
henriok
Posted: Fri Aug 01, 2014 9:28 am Post subject: |
I'm sticking to my analysis that Vegeta's processor is a RS64-IV. Soley based on die size comparisons of over a dozen images of different RS64-III and RS64-IV processors.
It still might be 600 MHz, since both RS64-III and RS64-IV came in that speed.
I find it very hard to believe that two chips with different die size, transistor count, and L2 cache support should use exactly the same substrate and capacitor layout. It's much more likely that two processors of the same specifications did. _________________ Always on the look out for POWER, PowerPC and Power Architecture information. For photographs, information and parts to buy. Am doing research at Wikipedia |
