kevclark78 Guest
Posted: Thu Sep 04, 2014 11:38 am Post subject: LAPTOP WONT TAKE CHIP UPGRADE |
hello ive just upgraded my lapton cpu (toshiba l300) from a intel celron 900 @2.20ghz. to a
Intel Core 2 Duo Mobile p8600 2.4 GH.
my bios is right up to date and the chip fits in fine and is usable in this board. ( i checked before i bought it) anyway i put the cpu in an put it all back together and it powerd up but the screen wont come on. (just a black screen) . so ive put the old cpu back in and the laptop works as it should.
ANY HELP WOULD BE APPRECIATED WITH THIS THANKS! |
mavroxur
Posted: Thu Sep 04, 2014 9:38 pm Post subject: |
| The Intel GL960 chipset (which is what the Toshiba l300 uses) won't support chips with a 1066MHz FSB. The fastest chip you could actually use is a Core 2 Duo T9500, which is actually a 2.6GHz core chip with an 800MHz FSB. Just because the chip fits (same socket) doesn't mean it's always compatible. |
Posted: Fri Sep 05, 2014 9:27 am Post subject: |
| so it wont work then mate no? |
Posted: Fri Sep 05, 2014 10:03 am Post subject: |
| hello mate just looked that chip up and they want £60 and onwards for it. is there anything cheaper i can get dual core? as i only payed £60 for the laptop. cheers |
mavroxur
Posted: Fri Sep 05, 2014 3:42 pm Post subject: |
| Just back it down a few notches to a T9300, they're half the price, and only 100MHz slower core (hardly noticeable). Same dual core, 6M cache chip otherwise. |
Posted: Sun Sep 07, 2014 12:38 pm Post subject: |
| thanks but there still like £30 is there anything a little cheaper plz? thanks |
mavroxur
Posted: Sun Sep 07, 2014 10:48 pm Post subject: |
| You might need to shop around. They're readily available on eBay for ~US$20 (about £10) all day long. I've bought several T9xxx series chips on ebay for upgrading laptops for resale. |
Posted: Mon Sep 08, 2014 8:33 am Post subject: upgraded my cpu on laptop now have a black screen HELP! |
Intel Core 2 Duo T7300 Laptop CPU SLAMD - 2GHz/800MHz/Socket P
would this work mate? |
mavroxur
Posted: Mon Sep 08, 2014 8:53 am Post subject: |
| It should work just fine. |
Posted: Mon Sep 08, 2014 6:10 pm Post subject: |
| Thanks mate! Appreciate the help |
mavroxur
Posted: Mon Sep 08, 2014 6:53 pm Post subject: |
| Not a problem. Be sure to upgrade to the latest BIOS before upgrading, too. |
