Intel QA92: is this a 2687W ES Chip??
Post new topic   Reply to topic    CPU-World.com forums Forum Index -> Memory, peripheral and other chips
jonsax
PostPosted: Wed Dec 17, 2014 2:43 pm    Post subject: Intel QA92: is this a 2687W ES Chip?? Reply with quote
Hello everyone!
This is my first post on this forum. I have a relatively simple question. I recently sold a pair of Intel QA92 ES chips on ebay. The buyer is claiming that they are incompatible with his motherboard and thought he was buying OEM chips. The listing clearly described these as ES chips and that they are NOT OEM and that compatibility should be figured out before bidding. He's claiming that because I put Intel 2687W ES into my description that I incorrectly described the chips. I see the QA92 chips described on web forums as being 2687W ES chips but that stepping is not listed on CPU world for the 2687W:
http://www.cpu-world.com/CPUs/Xeon/Intel-Xeon%20E5-2687...
So how can I get some sort of official "proof" that these are in fact 2687 W ES chips??? I can't seem to find any info on this! And the CPU world description doesn't list the QA92 stepping on their list of ES chips.
Any advice would be greatly appreciated. I want to do the right thing here, and if in fact these are NOT 2687 W ES chips, then I will return them and resell with more accurate descriptive info. But if I can find a way to verify them, it will save me some time and effort!!
Thanks all!!
PostPosted: Fri Nov 15, 2019 5:33 pm    Post subject: Re: Intel QA92: is this a 2687W ES Chip?? Reply with quote
jonsax wrote:
Hello everyone!
Thanks all!!
If you click on QA92, you will find that this site identifies it as either an unknown Xeon (this site has a part number for it, but no model number), or it could be a Celeron M (although I am sure you didn't get that wrong). I'm afraid that, as far as this site is concerned, there is no proof of it being a 2687 W. The info on the Xeon QA92 has it down as a socket 2011 chip that fits an mPGA478C socket, so is definitely not 100% accurate.
The only way to prove exactly what a chip is if unidentified any other way is to test it and use CPU-Z to identify it.
PostPosted: Fri Nov 15, 2019 5:56 pm    Post subject: Reply with quote
QA92 is a Xeon E5-26xx 3.00GHZ 8C20ML3 Sandy Bridge EP B0
Post new topic   Reply to topic    CPU-World.com forums Forum Index -> Memory, peripheral and other chips All times are GMT - 5 Hours
