Compaq VGA with Ati Rage Pro iic
Post new topic   Reply to topic    CPU-World.com forums Forum Index -> Vintage Electronic Components
BartOraj
PostPosted: Fri Jan 30, 2015 12:30 pm    Post subject: Compaq VGA with Ati Rage Pro iic Reply with quote
Hi there i don't need to find what model of card it is. Can you help ?
https://plus.google.com/114557494324520455332/posts/YaGAdEuku4G
Only what i know now its from compaq server and its PCI-X version. Chipset Ati Rage 3D iic.
PostPosted: Fri Jan 30, 2015 12:38 pm    Post subject: Reply with quote
The photo is too blurry for me
PostPosted: Fri Jan 30, 2015 12:49 pm    Post subject: Reply with quote
Not pure videocard, it's also scsi-controller and have some other ports.
And it's not pci-x.
Often it's hard-to-impossible to find an info on such custom compaq/hp/ibm cards.
Vegeta
PostPosted: Fri Jan 30, 2015 1:15 pm    Post subject: Reply with quote
I think this embedded single board computer based on Geode CPU or similar. it's also have COM and LPT ports PS/2 BIOS speaker scsi-controller VGA card etc Memory is probably on the other side
Wanted: 4 x VT-25-A tubes
PostPosted: Fri Jan 30, 2015 2:22 pm    Post subject: Reply with quote
No, other side is empty and none of the chips is like Geode =)
BartOraj
PostPosted: Sat Jan 31, 2015 5:04 am    Post subject: Reply with quote
If its not PCI-X and ISA then its special port for Compaq ? I try find what model of server it is and maybe got some more tip Smile
Vegeta
PostPosted: Sat Jan 31, 2015 5:08 am    Post subject: Reply with quote
like EISA
BartOraj
PostPosted: Sat Jan 31, 2015 7:46 am    Post subject: Reply with quote
Yeah i see then its VGA + mini mainboard with SCSI controller for Compaq server and only work with few Compaq models Smile
mavroxur
PostPosted: Wed Mar 04, 2015 9:04 pm    Post subject: Reply with quote
It's a multi-IO card with a custom bus interface. Elsewhere in the target system was a CPU card w/ system memory.
Vlask
PostPosted: Sun Apr 26, 2015 3:35 pm    Post subject: Reply with quote
Maybe remote control card used in compaq server. Some exotic edition, has strange bus. Cpu is often there for remote connection use. These were combined with various drive raid controllers.
Something like this one - http://vgamuseum.info/index.php/cards/item/716-compaq-remote-insight-lights-out-edition
Might be also only multi io card without remote control. Compaq liked using these in servers, you had there a lot of free ports then. But seen server that required this kind of card to boot. These were named Server Feature Board.
Examples - with SCSI and Rage IIC PCI
http://vgamuseum.info/index.php/cards/item/101-ati-rage-iic-pci
With SCSI or ATA using Rage XL
http://vgamuseum.info/index.php/cards/item/108-ati-rage-xl
Not only mine graphics card collection at http://www.vgamuseum.info
Post new topic   Reply to topic    CPU-World.com forums Forum Index -> Vintage Electronic Components All times are GMT - 5 Hours
