Intel Premiere/PCI board Socket 4 doesn´t post
misace
PostPosted: Sun Feb 22, 2015 8:35 am    Post subject: Intel Premiere/PCI board Socket 4 doesn´t post Reply with quote
I have this Intel Premiere/PCI board Socket 4, but it doesn´t post. It has aditional 3,3V connector between PCI slots, which I donť have on my power source. Does anyone know if the board post without Aux connector connected?
Looking For Chips 386 J38605DX, Symphony FPU, Rise Tiger, MP6-II, Winchip 3&4, IDT C6-Early Logo, Nx686, Tesla 8088, L80C86, Bulgarian 8088, Pentium 4 QT69ES.
joekster
PostPosted: Sun Feb 22, 2015 8:43 am    Post subject: Reply with quote
I had one and can confirm that it'll work without the 3.3v power connected. The 3.3v power is only supplemental for PCI devices. Please note that the board does not support proper 3.3v pci - only 5v.
I would hook-up a speaker, the board is pretty good about beep codes. although there's nothing really replaceable on the board... at least you would know what its complaining about...
misace
PostPosted: Sun Feb 22, 2015 8:51 am    Post subject: Reply with quote
Thanks. I have connected speaker but no beeps at all. Tried many SIMM modules as I heard, that board is picky about RAMs. Tried 2 CPUs, power sources, ISA, PCI VGA. Probably is really dead.
joekster
PostPosted: Sun Feb 22, 2015 9:29 am    Post subject: Reply with quote
I found my board to be quite UN-picky about SIMMs. Board doesn't support EDO ram, but uses those modules just fine. Took 2-chip simms, 2k/4k/8k refresh, composite simms...
If no beeps, then I suspect the board is DEAD Sad
Can always try and "bake" it, maybe a good reflow will fix things???
joekster
PostPosted: Sun Feb 22, 2015 9:30 am    Post subject: Reply with quote
just noticed that your board doesn't have the 5.25v VRM (needed for 66mhz cpu). I would check the jumper settings and make sure the board is set for 5.0v (60mhz) on VRM and CPU speed.
misace
PostPosted: Sun Feb 22, 2015 11:26 am    Post subject: Reply with quote
Thanks for advice, FSB is set to 60MHz, but I didn´t try fast page RAM.
PostPosted: Sun Feb 22, 2015 12:34 pm    Post subject: Reply with quote
a POST Card is mandatory to solve the issue.
misace
PostPosted: Sun Feb 22, 2015 5:11 pm    Post subject: Reply with quote
If I set recovery jumper and install floppy drive, it wants to read from floppy Very Happy So I have to get bios from somewhere.
misace
PostPosted: Sat Feb 28, 2015 9:41 am    Post subject: Reply with quote
So I repaired BIOS from recovery floppy and the board works now, thanks for advice. Smile Glad to finally have the test board for my Socket 4 chips Smile
