Christina_andre Guest
Posted: Fri Oct 30, 2015 7:11 pm Post subject: medion pc mt6 problems |
| hi i'm working on a project with my grand daughter on a medion pc mt6 re-build and am having problems with some of the wiring emerging from the on/off switch to the motherboard. if anyone out there has a similar machine i would appreciate some advice |
Posted: Fri Oct 30, 2015 7:42 pm Post subject: |
| Typically there will be a double row of pins to connect the front panel wires such as power SW along a side of your mainboard. The cable should be labeled to indicate placement. |
