Help c3h5 fill in the blanks
PostPosted: Mon Nov 02, 2015 9:09 pm    Post subject: Help c3h5 fill in the blanks Reply with quote
I try to do my own research but some things are not easy to get information on.
I keep an excel document of all the chips I've collected with some basic fields and I have some blanks that I hope some of you can help me with.
First up, package name or type and likely speed of the following.
PostPosted: Mon Nov 02, 2015 9:15 pm    Post subject: Reply with quote
Same for this chip
PostPosted: Mon Nov 02, 2015 9:20 pm    Post subject: Reply with quote
Same for this as well
PostPosted: Mon Nov 02, 2015 9:25 pm    Post subject: Reply with quote
Last for tonight, likely speed of these two.
PostPosted: Mon Nov 02, 2015 9:44 pm    Post subject: Reply with quote
HP info is here: http://www.cpushack.com/2014/03/18/the-forgotten-ones-hp-d5061-30xx-processors/
10MHz
PostPosted: Mon Nov 02, 2015 9:45 pm    Post subject: Reply with quote
88110 is the second implementation of the 88000 RISC processor (the first was the 88100), it runs at 50MHz
PostPosted: Mon Nov 02, 2015 9:48 pm    Post subject: Reply with quote
the SPARCs are marked
1580-8 8-core 1580MHz
1170-6 6-core 1170MHz
They are in an FCLGA 1831 (Flip chip glass ceramic Land Grid Array with 1831 pins)
PostPosted: Mon Nov 02, 2015 9:50 pm    Post subject: Reply with quote
the moto should be a CBGA361 (RS is the package designator)
Its made on a 0.65u process
PostPosted: Mon Nov 02, 2015 10:38 pm    Post subject: Reply with quote
Ah thank you for the info, I'm learning things. I did not expect those numbers to be the speed on the SUN cpus
PostPosted: Mon Nov 02, 2015 10:51 pm    Post subject: Reply with quote
Now I'm not sure what the 5061-3020 is.
PostPosted: Mon Nov 02, 2015 10:54 pm    Post subject: Reply with quote
ANother version of the 5061, I dont have documentation on it though
Birdman.
PostPosted: Tue Nov 03, 2015 12:50 am    Post subject: Reply with quote
5061-3020 isn't CPU. I've opened one and it has four small dies inside that look similar and quite simple. I haven't looked at it through the scope yet, but I'll try to take some pics when I'm at the scope.
aberco
PostPosted: Tue Nov 03, 2015 1:11 am    Post subject: Reply with quote
that 88110 is made by IBM, wow I would love to have one like that!!!
aberco
PostPosted: Tue Nov 03, 2015 1:12 am    Post subject: Reply with quote
The MCM is an IBM Muskie
aberco
PostPosted: Tue Nov 03, 2015 1:14 am    Post subject: Reply with quote
The SPARC T2 are BGA, not LGA
