Simmayor
Joined: 23 Apr 2003 Posts: 328 Location: Deventer Ov, The Netherlands
Posted: Tue Sep 16, 2003 6:08 am Post subject: Removing heatsinks |
Today i got three CPU's with the heatsink 'glued' on the CPU with some kind of thick thermal paste. The CPU's were AMD's, but the bottom did not have any print so i had to remove the heatsink to see what kind they were. I removed the heatsink and the print got stuck on the paste so the CPU was printless. It was only a 486 but unfortunately for me one of them was a DXL!
I have stil one CPU with the heatsink glued on it, is thare a save way to remove it?
Simmayor |
fRaSsL
Posted: Tue Sep 16, 2003 7:24 am Post subject: |
Yes! With heat from a gas burner. But be very careful, in some cases the bottom cover flew away with Mach1 or so  |
