Cyrix CX - JP
sammyc
PostPosted: Wed Jan 11, 2006 9:59 am    Post subject: Cyrix CX - JP Reply with quote
Have a look at this:
on the bottom it has CX - JP stamped on it. didn't really take any notice of it befor, but since looking through some of your collections I noticed it may have some significance.
Can anyone tell me what it means?
Sam.
PostPosted: Wed Jan 11, 2006 10:19 am    Post subject: Reply with quote
My reflection is that its from a pc manufacturer. Often there are small stickers or labels on cpus with internal codes for an pc manufacturer. This one uses a stamp. So it has nothing to do with Cyrix.
/T
sammyc
PostPosted: Wed Jan 11, 2006 10:51 am    Post subject: Reply with quote
Didn't think it would, but hey - you have engineering sample stamped down the side of your avatar in similar lettering. thats why I was questioning it.
PostPosted: Wed Jan 11, 2006 11:18 am    Post subject: Reply with quote
It is not stamped, its engraved in the ceramic. (and the cavity is filled with thermalpaste or something...) But i understand your questioning.
Edit: Look att the "135" to the right... http://www.recode.se/cpu/documents/38975581920050814113749.jpg
/T
sammyc
PostPosted: Wed Jan 11, 2006 11:46 am    Post subject: Reply with quote
/T
yes, sorry, the CX-JP is engraved. I'm sure a munufacturer wouldn't be silly enought to enrave on their own cpu right?
I have noted that some of the earlier CYrix's - 386(?)'s have JP in the part code.
EDIT -it's not engraved , it's stamped Rolling Eyes
PostPosted: Wed Jan 11, 2006 12:25 pm    Post subject: Reply with quote
Maybe : Cyrix - Japan ? I don't know.
x86sniper
PostPosted: Thu Jan 12, 2006 3:57 am    Post subject: Reply with quote
CX-JP is a notation used in Japan Cyrix CPUs
All Cyrix CPUs, as long as it is sold in Japan and pass through the Cyrix Japan Distributor (or Agent), bears this mark
ES is no exception
http://pc.watch.impress.co.jp/docs/article/980616/mii3331.jpg
sammyc
PostPosted: Thu Jan 12, 2006 4:21 am    Post subject: Reply with quote
ah ok. thank you for the info - is it a marking by Cyrix then or the distributor.
x86sniper
PostPosted: Fri Jan 13, 2006 3:22 am    Post subject: Reply with quote
By the distributor
It is from the same plant(s) as other unmarked MII / 6x86MX CPU
sammyc
PostPosted: Fri Jan 13, 2006 5:16 am    Post subject: Reply with quote
Anyone want to swap it with other Cyrix then? I dont want it
PostPosted: Sat Jan 21, 2006 7:32 pm    Post subject: Reply with quote
Im sorting out pictures posted in the forums and i compared this Cyrix with the ones in the newly created cpu library.
There seems to be a difference with other known mx:es. this CPU are missing the "Cyrix Corp" at the top, maybe thats why it says CX-JP instead?
Check http://www.recode.se/cpulibrary/Cyrix/6x86MX/200/index.html
Trade? Wink
/T
sammyc
PostPosted: Sat Jan 21, 2006 7:34 pm    Post subject: Reply with quote
well spotted. wil need to have a look when I get home.
4000+ chips.
4004-P4.
