How On Earth do I get this Heatsink off?????
sammyc
PostPosted: Sat Jan 14, 2006 10:48 am    Post subject: How On Earth do I get this Heatsink off????? Reply with quote
How do I get the heatsink off a Pentium II Chip?
I managed the first one with a bit of force and an alan key... but the next one seems impossible! I have now bent the alan key I went and bought for the job and cannot undo these screws!!
Any suggestions?
4000+ chips.
4004-P4.
PostPosted: Sat Jan 14, 2006 11:04 am    Post subject: Reply with quote
Carefully drill the head off. Use a drill bit about the diameter of the whole head, or just a bit smaller. Hold the heatsink in a clamp, and use a drill press.
Drill just enough to remove the head ( about 5mm max! )
Do this to all the screws and it should pull off.
skold
PostPosted: Sat Jan 14, 2006 11:38 am    Post subject: Reply with quote
lol. i still have one of those, with most of the heatsink.
i tore the fins off, but the plate is still on it. its totally stripped too.
sammyc
PostPosted: Sat Jan 14, 2006 11:43 am    Post subject: Reply with quote
I've bent an alan key and snapped a screwdriver so far, and I have about 40 to do!
4000+ chips.
4004-P4.
PostPosted: Sat Jan 14, 2006 12:03 pm    Post subject: Reply with quote
find a better allan key, and som anti-sieze like Kroil, or PB BLast (if available in england)
gmanbc
PostPosted: Sat Jan 14, 2006 7:08 pm    Post subject: Reply with quote
C4?
sammyc
PostPosted: Sat Jan 14, 2006 7:09 pm    Post subject: Reply with quote
LOL. I feel like it on these
I HATE PENTIUM 2's!!!!! Evil or Very Mad
4000+ chips.
4004-P4.
gmanbc
PostPosted: Sat Jan 14, 2006 7:14 pm    Post subject: Reply with quote
When I moved to Korea, I put all my P2 and higher stuff in storage and I have a ton of them with heatsinks that I couldn't remove. I know the drill works but If you figure out an easier way let me know.
Lee
