alexzu
Posted: Tue Feb 14, 2017 12:24 pm Post subject: OBTRONIX NIBBLER to test 4004 CPU |
Hi folks, anyone knows where to get Obtronix Nibbler and how much it can cost ? Found one on eBay, but the price ...
Thanks ! |
alexzu
Posted: Tue Feb 14, 2017 1:11 pm Post subject: |
So, which one is better ?
Anything special about Nibbler, except that it can run from regular batteries ? |
Posted: Tue Feb 14, 2017 8:07 pm Post subject: |
| alexzu wrote: | So, which one is better ?
I believe the lhf tester is better because of its smaller size and more convenient of using the USB power connector.
Don't forget lhf tester can also test the 4040. The price is also affordable for us.
Sounds like I'm the salesman of lhf tester  |
mcpublic
Joined: 19 Nov 2009 Posts: 4 Location: Boston, MA USA
Posted: Sun Jan 29, 2023 5:19 pm Post subject: Obtronix Nibbler battery wiring |
Does anyone know how the 3 x 9v battery connectors are supposed to be wired inside the Obtronix Nibbler? The web site is gone, and so are the assembly instructions.
The Nibbler uses one 7910 and one 7805 linear voltage regulator. |
