Masc_20 Guest
Posted: Sun Jul 30, 2017 2:46 pm Post subject: Upgrade a Toshiba Satellite L845D-SP4296FM |
| Hi, I want to upgrade my Toshiba Satellite L845D-SP4296FM, has a A8-4500M processor and i need to know if i can change the processor to a A10-5750M or what is the better procesor that i can use, thank you very much for your reply. |
Posted: Sun Jul 30, 2017 4:26 pm Post subject: |
| Probably yes. Of course it depends on BIOS support, but in my experience the Richland and Trinity mobile processors can be interchanged. A10-5750M is the best compatible processor. |
Masc_20 Guest
Posted: Sun Jul 30, 2017 8:27 pm Post subject: |
| Thanks for the answer, could you said me how can i check if my BIOS it's able to the change the processor? |
Posted: Mon Jul 31, 2017 6:05 am Post subject: |
Toshiba has the information about CPU compatibility. Usually this information is located in a service manual, but I did not find a service manual for Satelllite L845D. So I do not know.
You could try to contact Toshiba to ask them, but they probably will not answer. |
